Skip to main content
TalkTalk Help & Support
The Wi-Fi Hub
Our powerhouse Wi-Fi Hubs work seamlessly with your broadband or fibre package. With next-generation technology, they're smart enough to self-diagnose issues and manage their own updates. Expect outstanding performance all around your home, whatever you do online.
Wi-Fi Hub and Wi-Fi Hub Black image
Need some help?
If you need help with your Wi-Fi Hub, we've got you covered — just use the options below to find support guides that help with everything from setting up your Wi-Fi Hub to changing your Wi-Fi details.
Set up your Wi-Fi Hub
Your engineer should set up your Wi-Fi Hub for you as part of your installation. If you've moved house or you're replacing an old Wi-Fi Hub, we'll provide the instructions you need to get you going. To start, please select an option below.
Which Wi-Fi Hub do you have?
To guide you to the correct setup instructions, please select which Wi-Fi Hub you have using the options below. If you're having trouble identifying which router you have, check the sticker on the back of the Wi-Fi Hub - this will tell you which one you have.
Set up your Wi-Fi Hub or Wi-Fi Hub Black
You can find instructions for how to set up your Wi-Fi Hub or Wi-Fi Hub Black in our companion article, Set up your Wi-Fi Hub or Hub Black .
Set up your Wi-Fi Hub 2
You can find instructions for how to set up your Wi-Fi Hub 2 in our companion article, Set up your Wi-Fi Hub 2 .
Set up your Wi-Fi Hub 3
You can find instructions for how to set up your Wi-Fi Hub 3 in our companion article, Set up your Wi-Fi Hub 3 .
Set up your Wi-Fi Hub with a Part-Fibre connection
If you're using a Wi-Fi Hub with one of our Part-Fibre packages, check out our companion article, Set up your Wi-Fi Hub for Fibre 150/250 .
Set up your Wi-Fi Hub with a Full Fibre connection
If you're using a Wi-Fi Hub with one of our Full Fibre packages, check out our companion article, Set up your Wi-Fi Hub for Full Fibre .
Remedy a slow Wi-Fi connection
If your Wi-Fi is slow, there's a few things you can try to remedy the situation.
Improving your home Wi-Fi speed
To find out more on how you can improve your Wi-Fi speed at home, check out one of our companion articles below:
Running a speed test
If you suspect that your line or equipment might be faulty, a speed text is a great way of confirming whether the speeds in your welcome pack match the speeds you're getting today. To run a speed test:
Testing a fault with your Wi-Fi Hub
If you suspect your Wi-Fi Hub has developed a fault, then you may have to run some quick checks to confirm this. First, select one of the options below which best suits your concern with your Wi-Fi Hub.
Intermittent connection issues
If you're within your first few days of your new service going live, this is normal (check out Your first 10 days of broadband for more information). If you've had these concerns for a time, then it's worth investigating further. Select one of the options below to help us diagnose the problem.
Check your setup
Read our Check your router setup article to find tips on how to choose the best place for your Wi-Fi Hub to live in your home. If you've followed the information on this page and you haven't received positive results, select the option below to go to the next step.
Fix a dropping connection
If your connection keeps dropping and you're out of your stabilisation period, check out one of the options below to help you out:
If you've followed the steps above and you're still not receiving positive results, then it may be time to Report a Fault to us so that we can investigate further for you.
Router flashing orange?
The light on the front of your TalkTalk router lets you know whether it's working correctly and whether there are any issues with your internet service. You might find the light turns orange/amber when updating or trying to find a connection with our network. If your router has been displaying an orange light for 15 minutes or more, check out Why is my TalkTalk router light flashing orange? to find out how to remedy the problem.
Updating your Wi-Fi Hub's settings
You should keep your Wi-Fi Hub on at all times so that it can receive essential updates. This ensures your service performs optimally at all times. Sometimes you might need to update the settings of your Wi-Fi Hub, for example if you want to update your security settings. To update your Wi-Fi Hub, select one of the options below.
Change your Wi-Fi name and password
If you want to change your Wi-Fi name and password, you can! Just check out the options below:
Change your admin password
You can update your Wi-Fi Hub's admin password by following the instructions on our companion article: Change your router admin password .
Update your security settings
You can update your Wi-Fi Hub's security settings by following the instructions on our companion article: Change your Wi-Fi Hub's security settings .
Dim the Wi-Fi Hub's front light
Is your Wi - Fi Hub light too bright? Select this link and follow the instructions on our article to turn off the front light on your Wi-Fi Hub.
Reset your Wi-Fi Hub
You may be asked to reset your Wi-Fi Hub if you're experiencing a fault or if you've mistakenly changed a setting without meaning to. If so, you can Restore your router to factory settings using the instructions in this article.
  • Was this article helpful?
