Skip to main content
TalkTalk Help & Support
What affects your Full Fibre speed
Whenever you do anything online - whether that's sending an email or updating your social media - data is sent over your Full Fibre connection. The rate at which this data is sent is down to your broadband speed, which can be affected by many different factors.
For more information about what can cause slow speeds with Full Fibre, choose an option below.
Here's how an incorrect setup can cause slow speeds.
Router setup
Here's what can cause slow speeds within your home.
Your home
Here's how your router and devices can cause slow speeds.
Your devices
Think you might HAVE A FAULT?
If you've tried the above tips and none have helped, you might have a fault with your connection. See how your broadband is performing using our My Connection service. Run a connection test, check for issues in your area and get SMS updates on problems that are affecting your services.
Router setup
Your home
Your devices
Think you might have a fault?
If you've tried the above tips and none have helped, you might have a fault with your connection. If you suspect you might have a faulty line or equipment, chat to us in the TalkTalk PLUS app using the QR code or link below.
https://community.talktalk.co.uk/t5/Articles/What-affects-your-Full-Fibre-speed/ta-p/2585070
  • Was this article helpful?
