Skip to main content
TalkTalk Help & Support
Using Google Assistant
using google assistant
Learn how to do more on your TV using voice.
Hey Google
do more on your tv using your voice
Get a little help on your big screen. You'll need to be logged into your Google Account for this feature to work.
enjoy entertainment
Search your favourite shows and ask Google Assistant to turn up the volume, dim the lights or pause and rewind.
plan your day
Set reminders and timers, ask what the weather's looking like or check what the traffic's like on your route to work.
the personal touch
Get personalised updates when you sign in with your Google Account. including TV recommendations.
how do I use google assistant?
Simply press and release the Google Assistant button. It's the central button on your remote showing either:
Google Assistant Microphone button Google Assistant Molecule button
Microphone or Google Assistant molecule button.
You can then use your voice to search for shows, open apps, control smart devices, and more. If you would like more information on the different ways you can use Google Assistant on your TV, check out Google Assistant Help.
Press the google assistant button on your remote and try saying
Asking Google Assistant button
control your smart home
Use your voice to create the perfect viewing environment. Control smart home devices throughout your home. Adjust room temperature, lighting, or control other connected devices.*
*Requires compatible device, sold separately
Google, Google Play, YouTube and Chromecast built-in are trademarks of Google LLC
  • Was this article helpful?
