Using Google Assistant
Do more on your TV using your voice
Get a little help on your big screen. You'll need to be logged into your Google Account for this feature to work.
Enjoy entertainment
Search your favourite shows and ask Google Assistant to turn up the colume, dim the lights or pause and rewind.
Plan your day
Set reminders and timers, ask what the weather's looking like or check what the traffic's like on your route to work.
The personal touch
Get personalised updates when you sign in with your Google Account, including TV recommendations.
How do I use google assistant?
Simply press and release the Google Assistant button. It's the central button on your remote showing either:
Microphone or Google Assistant molecule button.
You can then use your voice to search for shows, open apps, control smart devices, and more. If you would like more information on the different ways you can use Google Assistant on your TV, check out Google Assistant Help.
Press the google assistant button on your remote and try saying
Control your smart home
Use your voice to create the perfect viewing environment. Control smart home devices throughout your home. Adjust room temperature, lighting, or control other connected devices.*
*Requires compatible device, sold separately
Google, Google Play, YouTube and Chromecast built-in are trademarks of Google LLC
