Skip to main content
TalkTalk Help & Support
About Total Home Wi-Fi
With Total Home Wi-Fi, you get guaranteed wall-to-wall coverage, eliminating blank spots throughout your home. This means you can be sure that everyone can get online, whichever room they’re in.
Total Home Wi-Fi creates a mesh network of multiple devices working together to blanket your home in reliable coverage. For just £8 a month, you get guaranteed coverage powered by a Wi-Fi boosting device, as well as access to our support team. We're here to help you maximize your coverage with advice and troubleshooting. And if you need an extra coverage boost, we'll send another device at no extra cost.
Benefits of Total Home Wi-Fi
Reach every room, guaranteed
Whether struggling to reach multiple floors or connect through thick walls, don’t worry. Total Home Wi-Fi is guaranteed to eliminate blank spots around your home.
Stream everywhere, guaranteed
Stream your favourite shows wherever you want to, whether you're stretched out on the sofa or getting cosy upstairs.
Work anywhere, guaranteed
Need to escape a noisy room for an important video call? Get peace of mind when you work from home with a connection that lets you dial in from any room.
Setup Support
Your Total Home Wi-Fi setup will be different depending on which equipment you're using. To help guide you to the right place, please select your router from the options below.
You're using an eero at home. Select an option below for further support.
I'd like help setting up additional eeros:
If your eero is already set up at home, you'll need to add additional eeros to your home Mesh network to achieve Total Home Wi-Fi. Check out our article Add or remove eeros from your network to find out how to do this.
I'm having trouble connecting devices to my eero:
Your eero uses the latest Wi-Fi 6 technology and any devices you use will need to be compatible. For help with problem devices working with your new Wi-Fi 6 network, check out our article Problems connecting a device to eero.
You're using a Wi-Fi Hub at home. Select an option below for further support:
I'd like help setting up my Wi-Fi Booster
Check out our article Setting up and positioning your Wi-Fi Booster to find support on using your Wi-Fi Booster with your Wi-Fi Hub.
I'm having trouble using my Wi-Fi Booster
Check out Troubleshooting for your Wi-Fi Booster to find tips on setting up and using your Wi-Fi Booster.
Identifying your router
If you're having trouble figuring out whether you have a Wi-Fi Hub or an eero at home, there's a couple of things you can check if you can't see the router itself (for example, if you're away from home or the router is hidden behind large furniture).
  • If you're on one of our Copper or Part-Fibre plans, you'll likely be using a Wi-Fi Hub. If you're on one of our Full Fibre plans, you'll likely be using an eero.
  • You can log in to My Account to find out which plan you're on.
  • You can check one of your previous Bill emails, which has an option to view your package.
Top tips
Setting up your new equipment closer to your router at first will allow them to establish a connection.
You can always experiment with the positioning of your equipment for best coverage and speed once they are set up.
Not stretching far enough?
If you've moved your equipment around and you're still not getting coverage everywhere you need it, you might need more eeros or Wi-Fi Boosters in your home network. To sign up for Total Home Wi-Fi or to request additional equipment for your home, you'll need to speak to one of our friendly team. Simply Login to My Account or the TalkTalk app to chat with us to add or update your package with Total Home Wi-Fi.
  • Was this article helpful?
