Skip to main content
TalkTalk Help & Support
Add or remove eeros from your network
You can add as many eero's to your network as you need. If you ever need to remove or replace an eero device on your network, it's really easy to do this in your eero app.
Adding an eero
Here's how to add a new eero to your existing network:
  1. Open your eero app
  2. Select the blue plus icon in the top right of your screen
  3. Now select Add or Replace eero Devices
  4. Select Add eero Device
  5. Follow the in-app instructions to add the eero to your network
Removing an eero
Here's how to remove eeros from your network:
  1. Open the eero app
  2. Select the eero you'd like to remove
  3. Select Advanced
  4. Select Remove "name" eero
  5. To finish, select Remove from Network at the bottom of your screen
Replace an eero
Here's how to replace an existing eero on your network with a new one:
  4. Select Replace eero Device
  5. Select which eero you want to replace
  6. Follow the in-app instructions to complete the replacement
  • Was this article helpful?
