Skip to main content
TalkTalk Help & Support
Wi-Fi Hub support
Wi-Fi Hub support
Our Wi-Fi Hub is packed with the latest tech to give you our strongest, fastest, most reliable Wi-Fi signal ever. Check out the below for help with using your Wi-Fi Hub and getting the most out of your connection. Click on the below options to discover how to get the most from your hub.
Wi-Fi hub icon
Wi-Fi Hub setup
Set up your Wi-Fi Hub using Wi-Fi, a wired connection, or WPS.
Wi-Fi details
Here’s how to personalise your Wi-Fi name and password.
Speed boost icon
Boost your speed
Check out our top tips for getting the best Wi-Fi speeds.
Security icon
Security Settings
Configure your Wi-Fi Hub to use WPA, WPA2, or both.
Gaming icon
Port forwarding
Set up port forwarding for gaming, file sharing, and more.
Top tips to boost your Wi-Fi
Tips to boost your Wi-Fi
1
Leave your Wi-Fi Hub on all the time. Turning it on and off will slow down your connection.
2
Keep your Wi-Fi Hub upright, up high and facing into the room for the best signal.
Not on the floor.
3
Face your Wi-Fi Hub into the room and don’t tuck it behind furniture or other signal-blocking obstacles
  • Was this article helpful?
