Skip to main content
TalkTalk Help & Support
Broadband Speed Code of Conduct
TalkTalk is a signatory to Ofcom's voluntary Broadband Speed Code of Conduct. The code aims to:
  • Govern the information we give you around the broadband speed you'll get when you sign up with us.
  • Protect you if you don't get the minimum speed we quoted during sign up.
  • Define the conditions under which you can terminate your contract without penalty.
We want to be confident that the speeds we promise you are accurate, so the speeds we quote during sign up are based on actual performance data from your line rather than estimates where possible.
Select which option applies to you below for more information.
The Broadband Speed Code of Conduct after 1st March 2019 protects you if your Throughput speed is lower than what we promised when you signed up with us.
Terms and conditions
You can register a complaint under the Broadband Code of Conduct at any time from the day your TalkTalk services go live. To be released from your contract without penalty:
  • Your throughput speed must be below the minimum guaranteed download speed provided to you at the point of sale. Remember, if you're a new customer, your line will go through a stabilisation period . This usually lasts for around 10 days and it's normal for your speeds to fluctuate during this time.
  • You must give TalkTalk 30 working days to try to resolve any network issues or problems with your line.
How to check your speed
You can check your current broadband speed using our speed test . Details about your expected broadband speeds are in your order confirmation email, including:
  • Your minimum guaranteed download speed
  • Your maximum upload/download speed
  • Your typical upload/download speed range
  • The upload/download speed we advertised for your package
If you want more information about what these speeds mean for you, read our guide that explains the speeds you need for different online activities .
What to do if you're getting slow speeds
If your broadband speed is performing at the lower end of your typical speed range, take a look at our tips for boosting your broadband speed .
The Broadband Speed Code of Conduct before 1st March 2019 protects you if your Sync is lower than what we promised when you signed up with us.
  • Your sync/line speed must be below the minimum guaranteed line speed provided to you at the point of sale.
You can check your sync speed in your router's settings. Your estimated speed range and minimum guaranteed line speed are in your welcome pack. If you don't have your welcome pack, put your telephone number and postcode into our availability checker and we'll show you your estimated speed range based on the conditions of the phone line in your area.
What to do if you're not getting your predicted speed
If you feel your broadband speed is slower than your estimated speed, the first thing you should do is take a look at our tips for boosting your broadband speed .
You can check your current broadband speed using the speed test tool in the eero app. Details about your expected broadband speeds are in your order confirmation email, including:
  • Was this article helpful?
