Changing your eero Wi-Fi name and password
Your wireless network name (SSID) is the name of the Wi-Fi signal being sent out by your router. You'll also need your wireless password to access your Wi-Fi on a device such as a smart phone or tablet. You can view or amend your network password anytime in the eero app.
New eero? Check out
our top tip
Save time not having to reconnect your devices to a new network by changing the wireless name
and password of your new eero to be the same as your previous router.
Changing the WiFi name
- Open the eero app
- Tap the settings icon in the bottom right of the app dashboard
- Then select Wi-Fi password
- You'll now be able to see your password
- To change it, tap Edit password
Changing the WiFi Password
- Open the eero app
- Then select Wi-Fi name
Once changed tap
Save
DON'T forget!
Any devices connected to your eero network will disconnect if you change your Wi-Fi name or password. You'll need to reconnect them afterwards using your new details unless you're using the same name and password as your old Wi-Fi network.
your eero hub
Get help, find out more and discover useful tips on how to get the most out of your service.
