Skip to main content
TalkTalk Help & Support
eero light too bright?
We've partnered with Amazon eero to combine the latest Wi-Fi 6 technology with our fastest, most reliable full fibre broadband. With eero, Total Home Wi-Fi is only a step away, boosting your Full Fibre connection for ultimate coverage.
Lots of our customers have been sharing how much they love the eero in our Community, and recently we've seen a few of you asking how to turn the light off. So, we've put together the below guide with instructions for turning off the LED on the front of your Wi-Fi Hub.
eero device
  1. Open the eero App
  2. Select the Home tab
  3. Select the Online button at the top of the screen to reveal the active eeros on your network
    (Note that if your eeros are offline or partially offline, this button may change)
  4. Select the eero that you’d like to edit settings for
  5. Select the Status light option
  6. Toggle the Status light switch to the desired setting to turn it either on or off
  7. Navigate to a new tab at the bottom of the page to save your changes
  3. Select the Online bubble at the top to reveal the active eeros on the network
    (Note that if your eeros are offline or partially offline, this bubble may change)
  6. Using the on-screen slider, select your desired brightness setting
If you’d like to manage the LED using Alexa, first make sure you have added the eero skillset. If you've not done so, check out our article, Using Amazon Alexa with eero , to find out how to set it up. After doing so and connecting your eero account to Alexa, just say
Alexa, ask eero to turn on the LED
OR
Alexa, ask eero to turn off the LED
to manage the light setting on your eero(s).
  • Was this article helpful?
