What is SoGEA and how is it different from Full Fibre?
What is SoGEA broadband?
Not every broadband connection is Full Fibre. If you're joining us on a part-fibre service, don't worry, we'll explain exactly what that means.
What is part-fibre broadband?
Part-fibre broadband uses a mix of fibre and copper cables to bring broadband to your home.
The fibre part of the network runs to your local street cabinet, while the final stretch to your home uses the existing copper network.
Traditionally, part-fibre broadband required a phone line service to be provided alongside your broadband.
What is SoGEA?
SoGEA stands for Single Order Generic Ethernet Access.
It's a newer type of part-fibre broadband that gives you a broadband connection without needing a traditional phone line service.
Like traditional part-fibre broadband, fibre runs to your local street cabinet and copper cables connect the final stretch to your home. The difference is that SoGEA is a broadband-only service.
That means:
- You don't need a traditional landline service for your broadband to work
- Your broadband runs over the existing part-fibre network
- You can enjoy reliable internet access without paying for a separate phone line service
In short, SoGEA delivers the same reliable part-fibre broadband connection, but without a traditional home phone line.
How is it different from Full Fibre?
The main difference is how the connection reaches your home.
| Part Fibre (SOGEA) | Full Fibre (FTTP) |
| Fibre runs to the street cabinet | Fibre runs all the way to your home |
| Uses copper cabling for the final connection | Uses fibre throughout the entire connection |
| Available in more areas across the UK | Currently available where full fibre has been built |
| Fast and reliable broadband | Our fastest and most reliable broadband technology |
Because Full Fibre doesn't rely on copper cabling, it can deliver faster speeds and a more consistent connection.
If Full Fibre is available at your address, we'll let you know when you place your order.
What about home phone services?
SoGEA is a data-only broadband service.
This means your broadband connection is active, but a traditional voice service isn't included as part of the connection today.
We're working on introducing voice services for customers on SoGEA, and we'll provide more information when these become available.
If you currently use a home phone service and are considering moving to SoGEA, we'll let you know what options are available to you during your order journey.
Do I need to do anything?
In most cases, no.
We'll guide you through everything you need when you place your order or switch your service. If an engineer visit is required, we'll let you know beforehand.
Need more help?
We're here to make getting connected as simple as possible. If you have any questions about your broadband service, get in touch and we'll point you in the right direction.
